201503-meetingparis [2015/03/25 09:28] hossein.mohammadi |
201503-meetingparis [2015/03/26 15:01] (current) jbossek add slides on algorithm configuration |
Line 31: | Line 31: | ||
**Research Reports and Updates II** | **Research Reports and Updates II** | ||
| 14:00 - 14:35 | Pascal Kerschke: Current research on exploratory landscape analysis {{:2015_03_23_numbbo_ela.pdf|Slides}}| | | 14:00 - 14:35 | Pascal Kerschke: Current research on exploratory landscape analysis {{:2015_03_23_numbbo_ela.pdf|Slides}}| | ||
- | | 14:35 - 15:15 | Jakob Bossek: Learning Feature Parameter Mappings for Algorithm Configuration via the Profile Expected Improvement | | + | | 14:35 - 15:15 | Jakob Bossek: Learning Feature Parameter Mappings for Algorithm Configuration via the Profile Expected Improvement {{:20150323-jakob-algconf.pdf|Slides}}| |
